Chaos Vantage v1.6.0 released
This is a sticky topic.
  • Chaos Vantage v1.6.0 released
    Hello everyone!
    We have released a new update - v1.6.0. Here are some of the highlights:
    • Added support for Cosmos materials, including Triplanar mapping
    • Added support for importing additional file formats:
      • FBX, OBJ, 3DS, PLY, STL, TER, DAE, GLTF
    • Added batch rendering UI:
      • The Snapshot and Sequence dialogs are now united in a single Render dialog.
      • Render jobs can be started as before, but they can also be added to a queue.
    • Added animation frame range setting to the render dialog
    • Added remaining render time estimation
    • Added default non-zero values for transform snapping
    • Added new "Import" item to the menu - similar to what we do with drag-and-drop
    • Optimized GPU memory usage: Light Cache is now several times smaller
    • Optimized GPU memory usage: unused textures are unloaded from the GPU
    You can find the full change log here:
    https://docs.chaosgroup.com/x/DgihAw
    You can download the update from here:
    https://download.chaosgroup.com/?platform=47&product=63
    You can see some of the new features in use here:
    Best regards.
    The Chaos Vantage team
    Hello everyone!
    We released a new version 1.6.1 with fixes and improvements:
    • Fixed live link animation started with Vantage UI rendering the same frame over and over
    • Fixed excessive shared GPU memory usage with certain large .OBJ scenes
    • Fixed HDR rotation not importing with vrscene generated from Revit
    • Fixed default up direction (now Y) for OBJ and 3DS files
    • Fixed UI issues when switching between Still and Sequence in the render dialog
    • Improved rendering: Results now better match the VRayUVWRandomizer in V-Ray for Cinema4D
    • Improved UX: Place tool now locks object orientation while Shift is pressed
    • Improved UX: Load sample HDR file when opening non-vrscene files
    For the full change log click here:
    Best regards.
      Hello everyone!
      We released a new update 1.6.2 with the following fixes and improvements:
      • Added support for the "auto" color space transfer function of VRayBitmap (V-Ray 5 update 2)
      • Fixed occasional line artifacts in interactive mode when using multiple GPUs
      • Fixed duplicate objects showing up in object list (with scenes from Maya)
      • Fixed issue with select-all undo in the objects list
      • Fixed crash when out of GPU memory and the scene has a rectangle light with a texture
      • Fixed issues in camera import script for 3ds Max
      • Fixed live link failing to start in specific circumstances (when "Save strings in legacy non-scene files using UTF8" is enabled in 3ds Max)
      • Fixed error when saving changes to the default configuration (defaults.vantage file)
      • Improved loading of .vantage files - if the root vrscene is not found with its absolute path it's searched for in the folder containing the .vantage file
      Best regards.
