Chaos Vantage v1.8.0 released
  • Chaos Vantage v1.8.0 released
    Hello everyone!
    Chaos Vantage v1.8.0 has been released and here are some of the highlights:
    • Added support for dynamic textures to reduce GPU memory usage
    • Added support for animated textures (image sequences) when using Live Link or loading .vrscene
    • Added Cloud system
    • Added Color Correction effects: Filmic Tonemapper; Hue/Saturation; Contrast
    • Added experimental option to increase FPS by decreasing sampling quality (Render -> Advanced -> Enable ray termination)
    • Added composition grid overlays
    • Added option to pause rendering after reaching a certain sample level
    • Added functionality to copy the viewport to the clipboard
    You can find the full change log here:
    https://docs.chaosgroup.com/x/DgihAw
    You can download the update from here:
    https://download.chaosgroup.com/?platform=47&product=63
    You can see some of the new features in use here:
    Best regards.
    The Chaos Vantage team
    Hello everyone!
    Chaos Vantage v1.8.1 has been released with the following changes:
    • Added Chromatic Aberration color correction effect
    • Fixed 3ds Max hang during Live Link caused by the cryptomatte render element
    • Fixed dialog placement on secondary monitor
    • Fixed the distortion of the contrails, used in the cloud system
    • Fixed motion blur in offline renders when dynamic textures are enabled
    • Fixed motion blur when rendering offline animation through Live Link from 3ds Max
    • Updated to latest Chaos License Server 6.0.0
    Best regards.
      Hello everyone!
      Chaos Vantage v1.8.2 has been released and here some of the updates:
      • Added "Always On Top" button in the top toolbar and shortcut (Ctrl+Alt+T by default)
      • Added option to denoise only final sampling pass in offline rendering
      • Added a default Physical Sun and Sky option in the Environment mode drop-down
      • Improved path resolving - every subfolder is searched for assets
      • Improved Motion blur post-processing - artifacts are reduced
      • Improved Vantage denoiser result in glass and flickering object edges
      • Improved glass quality when switching between Vantage and NVIDIA AI in Combined denoiser mode
      • Improved reflection detail with NVIDIA AI denoiser
      • Improved Auto exposure, so it can accumulate samples in dark areas
      • Improved snapping behavior when using the manipulation gizmos
      • Improved UX for slider controls - Soft range, CTRL, SHIFT and CTRL+SHIFT modifier keys for finer control
      • Improved UI - Added outline to the rollouts
      Best regards.
      The Chaos Vantage team​
        Hello everyone!
        Chaos Vantage v1.8.3 has been released and here some of the updates:
        • Improved performance on the RTX 4090 GPU
        • Improved UX - Increased default value of "Max. sec. ray intensity" from 20 to 200
        • Improved UI - Grouped exposure, highlight burn and contrast in Exposure group
        • Fixed choppy sun and clouds animation for animated geolocation
        • Fixed crash related to bump/normal mapping in a live link from V-Ray 6 for SketchUp
        • Fixed missing startup scene
        • Fixed missing render elements in EXR files
        • Fixed wrong rendering of scenes with override material
        • Fixed incorrect assets being loaded when resolving paths
        • Fixed wrong resolution for 720p preset in the HQ dialog​
        Best regards.
        The Chaos Vantage team​​
          Hello everyone!
          Chaos Vantage v1.8.4 has been released and here some of the updates:
          • Added support for repeat/offset u/v for Maya's place2dTexture when not using shading graphs (e.g. for bump maps)
          • Improved the metalness of a material to better match V-Ray
          • Improved reflective GI caustics
          • Many bug and crash fixes
          Best regards.
          The Chaos Vantage team​​​
            Hello everyone!
            Chaos Vantage v1.8.5 has been released. The updates include:
            • Initial support for VRmat materials
            • Support for alpha from bitmaps used in V-Ray material's opacity, exported from Maya
            • Support for all options of the Advanced mode of the Color Correction texture from 3Ds Max
            • New Environment tab, containing options affecting the rendering of the environment
            • Support for Edge trimming option in Chaos Scatter
            Best regards.
            The Chaos Vantage team​​​​
              Hello everyone!
              Chaos Vantage v1.8.6 has been released. The updates include:
              • Reverted IPR render state to be enabled automatically when in Live Link
              • Fixed random crash when closing Vantage
              • Fixed wrong first frame and duplicate frames during Live Link animation rendering
              • Fixed inconvenient soft range for the environment lighting intensity parameter
              • Fixed bug when trying to load RawBitmapBuffer of an image above 16k resolution
              • various bug fixes
              Best regards.
              The Chaos Vantage team​​​​​
