Chaos Vantage v2.6.0 released
  • Chaos Vantage v2.6.0 released
    Chaos Vantage v2.6.0 has been released and here are the highlights:
    • Added support for V-Ray Clipper
    • Added support for the VRayMtl SSS Translucency mode
    • Added support for opacity in Stochastic mode of the VRayMtl
    • Added Water surface object
    • Added support for the PhoenixFD Ocean texture
    • Added support for transparent VRayLightMtl
    • Improved Cameras represented as objects
    • Improved camera transitions with smoother trajectories
    • Improved support for animated Camera clipping planes
    • UX improvements
    ​You can find the full change log here:
    https://docs.chaos.com/x/DgihAw
    You can download the update from here:
    https://download.chaos.com/?platform=47&product=63
    You can see some of the new features in use here:​​​​​
    Hello everyone,
    Chaos Vantage v2.6.1 has been released and here are the highlights:
    • Added presets for the Water Surface object
    • Added support for vector mode displacement for the Phoenix Ocean Texture​.
    • Added SSS to the GI render element
    • Fixed unwanted camera creation for each camera move during Live Link when using .vantage scene loaded as a config
    • Fixed crash when loading a config file
    The Chaos Vantage team​​​​​
      Hello everyone,
      Chaos Vantage v2.6.2 has been released and here are the highlights:
      • Added an option for LOD bias when dynamic textures are used
      • Added the name of the selected camera in the scene animation track
      • Improved asset import - when dragging onto empty space, an implicit plane at height 0 is used for placement instead of the scene origin
      • Fixed the selected scene animation camera not being saved in the config file
      • Fixed black sky when the V-Ray 7 PRG sky model is selected. The V-Ray 6 model is still used
      • Fixed wrong rendering of Mesh clipper with SSS
      • Fixed wrong wave scale after hiding and showing a Water Surface object
      • Fixed ignoring the "loop animation" preference option when merging scenes
      The Chaos Vantage team​​​​​​
