Hi.
I've made my first test in Lavina and it has a very bright future. Even thoguh i have a 1080 ti i could make a very good render and it was very fast refreshing the renders.
If you have some time you can check the result here.
https://www.behance.net/gallery/9240...nd-with-Lavina
Anyway. One thing that could have an upgrade is the saving function because it doesn't seem to remember the last path to the folder and it redirects it every time to a path in the system drive.
Even though, it's one click solution for Real time walkthroughs. i hope to have some time to test more the recording features and try to transfer as many material modes as i can. The depth of field is also a great way for adding mood to the presentations. there should be a bit more of controls for that.
Way to go with Lavina!
Cheers
Cheers
