How much of the material info is imported into Lavonia
  • How much of the material info is imported into Lavonia
    So I exported a vrscene out of Rhino with 9 teapots and fairly complex materials. They went into Lavina easily but the materials were simplified. No bump maps, no texture maps, just the reflectivity and diffuse color. Is that a limit of Lavina currently.
    Let there B3D
    Steven Houtzager
    Intuitionusa.com
    3D Renderings & Animations for Product Development and Retail Design - Atlanta, GA
    Yes, there are limitations to what Lavina supports, it's a separate engine, not V-Ray GPU.
    We are working on minimizing these limitations.
    You can check the docs for more info on what's supported : https://docs.chaosgroup.com/display/...s+per+Host+App
    It will be very helpful, if you send me the .vrscene (with textures). My e-mail is in my signature.
    Then I will also be able to tell you what's most likely causing the differences.
    Greetings,
    Vladimir Nedev
