GPU limit?
  • GPU limit?
    hello. Does Lavina have a limit to the number of GPUs it can use? Not interested in NVLink, just wondering if it would work on a machine with 4 or even 8 GPUs?
    thanks
    doug
    -DW
    -buck.co
    Yes. Project Lavina is limited to using 2 GPUs, and automatically uses your most capable GPUs if you have more than two.
    Kind regards,
    - Phil
    - Phil
    VP Product Management, Chaos Group
      If the GPUs are NVLinked, the whole group counts as 1 device towards this limit, so you could run a 4-way "SLI" setup for example (this was fixed in 0.5.0 -- it didn't work properly before). The issue with many separate devices is that the PCI-e connection is too slow.
      Nikola Goranov
      Chaos Developer
