Lavinia does not start
  • Lavinia does not start
    Hello everyone, Lavinia does not start. I tried to reinstall the application and I updated the GPU drivers, but I didn't fix it. Can you help me? . My workstation : Epyc7702P + RTX 4000+ 128GB RAM
    thanks to all for help
Name:	Immagine 2020-10-05 125722.jpg
    we will release a build with a fix for this very soon.
    Meanwhile, you can try what this post suggests : https://forums.chaosgroup.com/forum/...51#post1086351
    """Open a command console in your Lavina folder and enter: set VRAY_NUM_THREADS=30 and then type lavina.exe to launch Lavina.
    If that works, you can put that into a .bat routine and make a shortcut to it on your desktop to make it easier if you'd like."""
    But you will have to remember to NOT use this work around with the fixed builds, as limiting the number of threads can slow down mesh and texture loading.
    Greetings,
    Vladimir Nedev
      Thanks a lot. I'll try right away
        The updated version is released. You can download it and forget about the command line hack.
        Nikola Goranov
        Chaos Developer
