Environment Mode of Vantage
  • Environment Mode of Vantage
    Hi
    I've tried the new Chaos Vantage released just before, it's pretty cool. When i watch the video about introducing Lavina BETA on youtube, i notice that in BETA version there is a Physical Environment mod option which is quite similar to Vray sky map, but now i can not found it in the Vantage 1.0.
    Is that something i missed or you just removed this option for some reason?
    Thanks
    Billd
    Hi yi_xiang
    The Physical Sky mode in the Environment tab is only present if there is a sky model in the opened .vrscene. If you open a .vrscene without a V-Ray sky the option will not be available.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Actually you need just a V-Ray Sun light in your .vrscene for the 'Physical Sky" option to show up.
      The reason for this is that creating lights in Vantage is not yet possible and the 'Physical Sky" needs a sun light from which to get its properties.
      Greetings,
      Vladimir Nedev
        Thanks for your prompt reply, and i found the Physical Sky in Vantage.
        Thanks again.
