error memory
  • error memory
    Hello Guys, here is the following error occurring with a certain frequency.
    In a scene of 2 million poligos and with 5 million vertices? I get the message out of memory.
    Could it be an error with some specific material?
    My set is a TR4 2970wx, 64GB of ram with an RTX 3080 10GB.
    Ty
    The required memory depends on many things:
    - geometry complexity (what you mentioned)
    - textures
    - render resolution
    The available memory depends on:
    - other 3D apps that might have reserved memory, in which case Direct3D gives Vantage a smaller memory "budget"
    If you click "yes" in that dialog, Vantage will try to go over its allocated memory budget.
    Does the scene load then ?
    Greetings,
    Vladimir Nedev
      Vladmir, I believe then that it may be as much for the geometry as for the maps, some attempts with only part of the files, it loaded.
      I need to be aware of that.
      In a test with 100,000,000 polygons of some blocks copied in instance, the consumption of vram was very low.
      Thanks for sharing.
      Best Regards
        Hmmm... So is your file larger than the utopia sample file used to market Vantage? I thought large datasets were Vantage's strong points. Do users need to have multiple gpus to achieve that benchmarks demo'd?
