Vantage Performance
  • Vantage Performance
    Hello, I noticed that after the latest update of Vantage, Vray and 3ds max 2022,
    performance during the live link is significantly slower.
    The render time also seems to be slightly slowed down.
    I have been testing several project files that I have been working on for several months.
    System: RTX 3090 Ram 64 GB AMD 12 core 3900XT
    Hello, I noticed that after the latest update of Vantage, Vray and 3ds max 2022, performance during the live link is significantly slower.
    Do you mean the lag between changing something and seeing the change in Vantage ?
    This is most likely an issue on the V-Ray or 3ds Max side of things.
    Which previous version worked better ?
    The latest Vantage version supports the clear coat layer in the V-Ray Material.
    If you have materials that use it, rendering will be slowed down, yes.
    You can disable the clear coat on all materials from the "Render" tab if you don't need the added effect.
    Can you tell me which two Vantage versions you are comparing and what's the difference in render time ?
    Greetings,
    Vladimir Nedev
