what's wrong with vantage
  • what's wrong with vantage
    when change the render size
    This is probably happening because your GPU doesn't have enough VRAM to compute the new resolution. What is your hardware and to what resolution are you setting it to?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Have you disabled the "Safe GPU allocations" checkbox?
      Nikola Goranov
      Chaos Developer
        Yes , I had already done,but ,some zize can be rendered out and default 4k 1080P
        Sure to be rendered
          I think :after changed resolution ,dont click "enter",click any other checkbox to take foucs from resolutions,sometimes the aspect locked the resolution isn't right.
          good luck
            Really good image - very well designed
            I'm curious; where did you find the rope artwork...or did you model it yourself?
            EDIT: Don't worry, I found it It is macrame, for anyone else who is interested.
