Crash every time I export vrscene
  • Crash every time I export vrscene
    MAX 2021, vray 5 update 1.3
    First I thought it was my scene (maybe it is) but now I tried an another scene and it also happens. I use MS (which exports fine for Vantage), also use floor generator...not sure what else
    www.hrvojedesign.com
    Hi Crayox13,
    Is this happening even on a simple scene with just a simple cube and a light? Does Vantage crashes or simply vanishes without a message? Do you have a single or a dual GPU? Any screenshot/recording of what is happening will help us resolve this quicker.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      MAX crashes after the scene is exported. Both of those scenes actually exported fine and I was able to load them in Vantage where they also worked fine.
      So MAX doesn't crash at all my scenes but on those two it does. Haven't tested many yet.
        Are you using the Vantage toolbar to export a vrscene or the standard export dialog provided by V-Ray for 3ds Max? If the crash reproduces with the standard export dialog, it is not Vantage related.
        Nikola Goranov
        Chaos Developer
          Yes sorry the standard export scene. Should this thread be moved then?
            Yes, I think the Max team should handle this.
            Nikola Goranov
            Chaos Developer
