Color Correction
  • Color Correction
    I'm having problems with Color Correction in 3ds max, I make color adjustments but in vantage nothing happens.
    The sphere material is supposed to be the lightest wood material.
    Are you using the standard 3ds Max color correction node ?
    Does the issue get fixed if you restart the live link ?
    We will need to examine the material graph in order to figure out if something is unsupported or if there is some issue with the live link.
    Greetings,
    Vladimir Nedev
      Hi Pablo,
      In addition to what Vladimir said, can you send us a sample scene of the issue so we can try to reproduce it here?
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
        Hi
        I found this post because I'm having similar problems. I have attached a simple scene with two boxes with same diffuse map and two different ways to control the color. Another is made with Hue/Shift and it works just fine, but usually I use the Advanced settings and it doesn't work. Rendering with V-Ray, both works just fine. I guess this is a known issue by now?
        Thanks
        Mikko
          Originally posted by MikkoK View Post
          Hi
          Thanks
          Mikko
          Thank you for the descriptive example scene.
          We will try to fix this for the next release.
          Greetings,
          Vladimir Nedev
            Hi
            Thanks
            Mikko
            This is fixed in the 1.8.5 build that we released last week.
            Greetings,
            Vladimir Nedev
              Greetings,
              Vladimir Nedev
              Great, thank you!
