Too much denoiser
  • #16
    I mean the AA samples per pixel. See attached image.
    Greetings,
    Vladimir Nedev
    • #17
      Where do I find that menu?
      • #18
        I thought you were using the Tools -> High Quality Render command inside Vantage ?
        How are you rendering the animation otherwise ?
        Are you using the live link animation command ?
        It has the same Samples option, but it defaults to just 10.
        Greetings,
        Vladimir Nedev
        • #19
          I'm using the "Render animation via Live Link" button in 3d Studio.
          • #20
            In this case, the corresponding option is this one:
            It defaults to just 10, which can easily lead to the issue you are seeing.
            Greetings,
            Vladimir Nedev
            • #21
              Ah....then it's 100.
              • #22
                Maybe try increasing the Samples somewhat.
                Or try disabling Reduce flickering - in my tests this seems to get rid of the glow.
                Greetings,
                Vladimir Nedev
                • #23
                  Just up the samples to 300 and see.
                  • #24
                    Thank you, that was it!
                    • #25
                      You are welcome, 300 samples seems the sweet spot for animations
