Copy Object
  • Copy Object
    Hello, Is there any way to copy objects in Vantage?
    Hi yones,
    Currently there isn't a way to duplicate/copy objects inside Vantage but it's in our To Do list. Unfortunately I cannot give you a timeframe when this feature will be available.
    Alexander
    Alexander Atanasov
    Chaos
      Please add this feature as soon as possible it would be great to have!
        Hi stephen_moore,
        Yes, this is something that is being worked on at the moment and will be available in some of the next releases. Please keep an eye at the Announcement section where we post new releases and changelogs.
        Alexander
        Alexander Atanasov
        Chaos
          I would greatly appreciate it if you could promptly add this feature to the system. It is a crucial aspect that is currently missing.
            We have this feature in Vantage 2.0. You can select objects and press Ctrl+D to duplicate them.
            Note that :
            - the new objects are instances of the originals and are saved in the .vantage file.
            - the new objects have the same transformation as the original, so you need to move them (the move tools is auto-activated with ctrl+d).
            - you can keep pressing ctrl+d while moving an object if you want to quickly scatter it (a tree) for example.
            Greetings,
            Vladimir Nedev
