Animation
  • Animation
    Hi have created an animation in Vantage how can you make the transitions between the cameras softer? Is it possible to copy the settings from camera to camera in the timeline or to update several cameras at the same time with one setup?
    Thank you very much
    Hi Mr Pock,
    What do you mean softer? Does changing the transition time or duration not work for you?
    Do you mean transition settings? There isn't currently a way to copy-paste either camera or transition options. Will add it as a request. Can you please give an example what would you wish to update to multiple cameras at once?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
