The save as default option is not working since version 1.6
Save as Default
Hi, Pablo,
Yes, we are aware of the issue and we will be fixing it in the next release. We plan to improve the experience with the following:- remove the checkbox 'Save defaults'
- the next time you open the Render setup dialog will load the last set parameters from the previous time it was opened
- the current method with the checkbox
- the 'auto-save and load' feature between sessions of the render setup dialog
AlexanderAlexander Atanasov
Chaos
Alexander
Alexander
Alexander
Hi 18322119@qq.com,
It will retain most but not all. In the example the green parameters will be retained between session and the ones in yellow will be reset when you close and reopen Vantage: https://drive.google.com/uc?id=1d9ef...Hb7ptqeXFU7spC
Chaos
Hi 18322119@qq.com,
We plan on implementing saving render settings to the vantage file so that every project can load it's own settings but that will come at a later stage. We will let you know when this is available.
Chaos
