Export TyFlow Animation to Vantage
  • Export TyFlow Animation to Vantage
    Hi..,
    i've seen people are using TyFlow animation in Vantage...Is there any tutorial that shows how to export TyFlow animation to Vantage?? I created a curtain animation with TyFlow..i really needed to work that animation in Vantage...It seems Marvellous Designer animation wont work with Vantage....
    Thanks in advance
    Hi abdul_rahman,
    These sort of animations (deformable meshes) are not currently supported from vrscene files. However, you can render them using the "Render animation with Chaos Vantage" from the Vantage toolbar in Max:https://docs.chaos.com/display/LAV/R...Vantage+Script
    We do plan to add support for deforming meshes in the future but cannot say when. Please try to render the animation using Live link and tell us if it works for you.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thank you....using "Render animation with chaos vantage" works well but the only problem is i cannot control any lights inside vantage except auto exposure..since i have many lights in the scene..hoping the animation feature will be implemented soon and it really helps many.... one more thing i need to confirm is frosted glass material still not supported?
