Originally posted by vladimir.nedev
View Post
Video Flickering
The noise in the lantern in front of the house can definitely be improved by more light tree samples.
It's hard to say what the ideal combination is.
500 AA samples can be too much or too little depending on what you have in the scene.
If you have lots of lights, using more light tree samples might be better than increasing AA samples.
You can try different setups by rendering a few frames until you are happy with the result.
Greetings,
Vladimir Nedev
- Likes 1
Originally posted by vladimir.nedev View Post
Not sure, you might have to increase the number of AA samples instead.
How many light tree samples did you use ?
Some of this jittering could be caused by the light cache too, but it's hard to tell.
Greetings,
Vladimir Nedev
Originally posted by mruiz79 View Post
HI! here is how the final video looks. Still has some flickering, a lot less, but is still there. I used 300 samples and 16 light trees. Is there anything else I should bump up? thanks!
- bump up the AA samples even further than 300 OR
- try disabling the light cache from File->Advanced settings, as it could be causing flickering in some cases
(this could also lead to more flickering however).
Greetings,
Vladimir NedevLast edited by vladimir.nedev; 26-08-2022, 05:57 AM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Hi! moved to another project and now I have more questionsmaybe in the same subject. I'm rendering at 4k, AA 400, and 12 light trees.
1. If you ay 0:02 the light coming from the door and projecting under the dark sofa changes of angle, the reflection, why does this happen?
2. In the background you can see some flickering on the edges of the objects, I'm assuming this happens bc of the camera speed vs the frame rate (currently at 30fps), would you agree?
Thanks!
Originally posted by mruiz79 View PostHi! moved to another project and now I have more questionsmaybe in the same subject. I'm rendering at 4k, AA 400, and 12 light trees.
Thanks!
Can you send us the scene or at least the floor with its material and textures ?
Greetings,
Vladimir NedevLast edited by vladimir.nedev; 04-09-2022, 01:25 PM.Vantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
Nikola is right, it's most likely the dynamic textures in combination with bump mapping that's causing this.
Greetings,
Vladimir Nedev
Scene:
https://1drv.ms/u/s!AtuTwSNTDiaJiesL...Fiv6Q?e=xWvH7e
Floor texture:
https://1drv.ms/u/s!AtuTwSNTDiaJiYdf...rjqgQ?e=FCAmXi
HI, here is the link to the scene and texture. The floor is created using the floor generator.
Scene:
Floor texture:
Greetings,
Vladimir Nedev
The first link doesn't seem to work, it says the file is either missing or I don't have access.
Greetings,
Vladimir Nedev
https://1drv.ms/u/s!AtuTwSNTDiaJifAt...kmCzw?e=rF4DxZ
Originally posted by mruiz79 View Postoh, weird, here is an updated link, 1.6 GB:
I don't think that's the correct one ?
Can you please save the floor in its own scene and make sure it has the correct material and also that the OneDrive link includes all required textures ?
Greetings,
Vladimir Nedev
Thanks, but in that scene the floor has a material called "Piso COncreto" with a bump texture called "d8684792_Bump_4k_raw.tx".
Greetings,
Vladimir Nedev
Max file:
https://1drv.ms/u/s!AtuTwSNTDiaJifId...-CJMw?e=py8nVM
Vantage settings:
https://1drv.ms/u/s!AtuTwSNTDiaJie4C...QDGVg?e=iyk5bq
Hi, the object is called "000 WOOD FLOOR". Here is the correct link:
Max file:
Vantage settings:
Please save the object separately (from File->Save Selected...) as I can't keep downloading and checking 1.5 GB max files each time.
Also I need the textures for the material, mostly the bump texture.
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
We've released Vantage 1.8.2, where the flickering issue with dynamic textures + bump mapping should be fixed.
However, we've tested only internal scenes to confirm the fix, as we didn't receive any user ones.
Greetings,
Vladimir Nedev
