Camera Exposure
  • Camera Exposure
    Hello
    I did an animation and Would like to take some questions.
    I exported the animated cameras of 3ds max but they did not come with the exposure predefined, I made the adjustments of exposure values in vantage but when I have it rendered back to the standard.
    I had to leave the camera display in "none" and adjust the exposure manually on the general exposure slider.
    Is there any way to change the individual exposure of cameras imported from 3ds max?
    Interior Chaos Vantage - YouTube
    Are you using Max's Physical camera or the V-Ray Physical Camera ?
    Greetings,
    Vladimir Nedev
      Greetings,
      Vladimir Nedev
      https://drive.google.com/file/d/19cN...ew?usp=sharing
        Hi Pablo,
        V-Ray physical exposure is supported and should match V-Ray. For the second video this is normal behavior because when you playback the camera gets reset to imported properties. You have to Save(overwrite) to the camera after you made the changes but you will lose any transform animations associated to it from the vrscene. Can you send a scene so we can examine it?
        Alexander
        Alexander Atanasov
        V-Ray for Unreal & Chaos Vantage QA
        Chaos
