After using the direct link to Vantage from MAX...I noticed that I have to exit MAX and get back in in order to be able to export a .vrscene from MAX. Am I doing something incorrect or is that normal?
Can't export .vrscene...
You just have to stop the live link (or V-Ray IPR) first.
It can be very confusing as there is no message to tell you why the export is not working.
Greetings,
Vladimir Nedev
Hi Luma3d,
If you use the 'Export and send the current scene as static .vrscene to Chaos Vantage' button in 3dsMax the script will automatically:- Stop Live Link session currently running.
- Start Chaos Vantage if it is not already running.
- Еxport the scene in a .vrscene file in the .max project location with the name of the .max file.
- Open the scene in Chaos Vantage.
Alexander
Alexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
