About how to make an animation with moving object
  • About how to make an animation with moving object
    HI, recently I downloaded Vantage and I found that some people can make animation with moving objects. Does anyone know how to do this? Because every time I make a change to a object , Vantage will update the change for all scene , so there I can't record how the object moves/hided.
    Click image for larger version  Name:	image.png Views:	0 Size:	629.7 KB ID:	1171361Click image for larger version  Name:	image.png Views:	0 Size:	927.3 KB ID:	1171362
    Click image for larger version  Name:	image.png Views:	0 Size:	122.6 KB ID:	1171363Click image for larger version  Name:	image.png Views:	0 Size:	148.3 KB ID:	1171364
    (Image 1 & 2 are captured from a video and image 3 & 4 are captured from another video, but they all moved in one shot)
      Hi Priscilla,
      The videos that you are referencing were probably created in a DCC that can create animations and then export them in the vrscene or use the 'Render animation with Chaos Vantage' when in Live link feature, like 3ds Max for example. As far as I know you cannot create such animations inside SketchUp.
      Currently the following types of animations are possible to create in Vantage:We are looking into ways to implement creating object and light parameters animations from inside Vantage but they will be implemented at a later stage.
      Alexander
      Alexander Atanasov
      V-Ray for Unreal & Chaos Vantage QA
      Chaos
