Vantage not saving frames
  • Vantage not saving frames
    Using the "render animation with Chayos vantage" button and set it to save files on my desktop.
    It renders the animation just fine, but no files are being saved. I wonder if its a firewall issue. Any ideas?
    mdi-digital.com
    Hi mdi,
    How are the files named and what is the path location(does it exist)? Maybe there are some symbols that cause the rendered frames to not be saved.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Originally posted by Alexander.Atanasov View Post
      Hi mdi,
      Alexander
      i can't see anything unusual, its just saved into a folder on the desktop that already exists - files are simply named "test" and are being saved as Jpgs or PNgs (I've tried both)
      mdi-digital.com
        ive restarted the pc, updated Vray (I was on hotfix 2, I'm now on 3) and still no go.
        If I go to vantage and render a frame from there it renders and saves it just fine. When using the "render animation with Chaos vantage" from max that it doesn't save anything. It renders the while animation without saving a single frame.
        mdi-digital.com
          Panic over! pesky virus software blocking the app! all fixed now!
          mdi-digital.com
