Workflow for pipeline with different lighting situations
  • Workflow for pipeline with different lighting situations
    Hi there, I'm getting started with Vantage and try to understand the render pipeline...
    The scenario: as a lighting designer I'd like to show different lighting situations (artificial light / daytime /nighttime) to our customers. So I have my Vray lights in my scene that I want to switch on and off or dim in intensity in different renders.
    So my thought was to set the dim levels (or visibiility of the element), save it to a camera and fire up the pipeline and put it into the render pipeline. But as far as I can see, the settings for lights are not saved in the camera view.
    Is there a workflow that allows having multiple lighting scenes render in one queue? For now, I make my settings, render a single picture, change the settings, render again and so on..
    Is there an easier way to do this?
    Thanks a lot for hints & tricks!
    Oliver Link
    Hi Oliver,
    We are working on a solution for a scene state system which includes lighting scenarios but it is still in development. We will let you know when the feature will be available. As a current workaround you can save separate .vantage files for the different light setups and load them when needed.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Alexander, thanks for the info. I'll be patient waiting for new features, I have to say even without some features still in development, Vantage is amazing!!
      best
      Oliver
        I think if you use live link, you can do a real-time presentation with your clients by grouping lights and turning them on and off as needed.
