Testing Vantage for first time
  • Testing Vantage for first time
    I just started playing with Vantage and trying all kinds of settings.
    I converted one of my Corona scenes to Vray to try it.
    Question: How to enable caustic with Vantage? I'm using only HDRI for lighting.
    4000x2500, 3000 samples, 3min. RTX4090
    look like cant support caustic yet, but can try use texture to fake it
    https://www.youtube.com/watch?v=zUo_OmjKC8o
    www.archcg.my
      You probably don't need so many samples if you're using the denoiser. The engine is compatible with V-Ray scenes but it has its own render settings.
      Nikola Goranov
      Chaos Developer
        Hi guys,
        Currently Chaos Vantage can only generate GI reflective caustics(which can be enabled in the Render tab>Advanced rollout>Reflective GI caustics) and doesn't have a proper refractive caustics solution. This is something that we may look into in the future. For now as a workaround you can achieve a similar look with the suggestion from cmjohncheng.
        Alexander
        Alexander Atanasov
        Chaos
