image sequence texture from maya to vantage
  • image sequence texture from maya to vantage
    hello, I'm trying to make an animation of moving ocean waves; connecting a noise png sequens to the bump and setting it to sequens, (it is working inside maya!).
    Export the project to vrscene, but i dont get any animation on the texture? the sequens format is ocean.[###].png also tried ocean_[###].png.
    any help will be greatly appreciated,
    Does it work with a live link from Maya to Vantage ?
    Did you select Animation -> Standard when exporting the vrscene ?
    When inside Vantage, you have to press 'u' to update the current frame.
    It's not done automatically for performance reasons - we have yet to implement a caching scheme.
    If you use Tools -> High Quality Render, the frames should update automatically.
    If the above is not working, we will need a maya/vrscene for investigation.
    Greetings,
    Vladimir Nedev
      Yes, it works with a live link from Maya
      I'm using Maya 2023.3 and Vantage 1.8.6
      also selected Animation -> Standard when exporting the vrscene.
      I'm aware of that I have to press "U" but still no changes, the texture is static
      here is a link to the Maya scene and the vrsence:
      https://drive.google.com/file/d/1RuY...ew?usp=sharing
        You are right, it doesn't work, thanks for the scene.
        We will fix it for future builds.
        Greetings,
        Vladimir Nedev
