Hi everyone
i am facing 2 issues with chaos vantage 2..
1.i was working on a scene earlier in chaos vantage 1.8.6 version. it was working perfectly fine.it was a big scene with lot of forest objects . i had made the complete animation and was almost done with the project. Then i upgraded to Vantage 2 ( to be able to add anima characters) and suddenly the scene is impossible to even navigate. (see attached image frame rate)
https://i.postimg.cc/05JF8m8H/vantage-2.jpg
even zoom pan is crawling.i even tried vrscne export but same thing happening.
But as soon as i load the old vantage 1.8.6 scene as "config only" the scene works fine like it was working in vantage 1.8.6. whats the issue? see attached image for frame rate
https://i.postimg.cc/VNpgTGbs/vantag...-as-config.jpg
2 also when i open the old "open as config only "file in vantage 2 i get an error 3 cosmos package(image attached)failed to load
https://i.postimg.cc/BnwBLYp5/cosmos-error.jpg
and i see a weird object(attached image)
https://i.postimg.cc/cCZRyV1W/old-ob...r-in-scene.jpg
that i had made long back in the scene when i was using 1.8.6 but i had deleted it and its no longer there in the 3dsmax scene but it somehow got saved in this config file and whenever i load this vanatge scene as config it appears.
update: when i export the vrscene the cosmos error dont appear as i am able to access cosmos browser and also i am able to delete that weird object. but when i again use live link i get that cosmos error and that object appears again. i tried deleting the object in vrscene and then importing changes from vantage to 3dsmax it gets okay but then again when i use livelink i get cosmos error and that object is again visible. i am totally frustarted with this
please help with the above issues.
thanks
thanks
