Render queue sequence from selected cameras
  • Render queue sequence from selected cameras
    Hi
    Is it possible to set whch camera to render from for a sequence similiar to the still image render queue?
    I noted in the manual under sequence rendering it says - Scene state – Specifies the rendering camera from a list of available scene cameras or <current camera> position.
    However I am unable to select a camera for sequence rendering , either imported or created in vantage, is there a way to do this?
    Thanks​
    Hi Bionics,
    There was a mistake in the docs, it is fixed now. The Scene state specifies a scene state from a list of created scene states to apply when rendering or to use the scene's current state when <chosen scene state>. Currently you cannot specify an animated cameras to render as a render queue, only the camera setup in the animation editor is used. We do plan to include such an option in the future.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
