Chaos Cosmos - Fabrics
  • Chaos Cosmos - Fabrics
    Good morning, in the Cosmos of Vantage appears 70 fabrics and in the Cosmos of SketchUp 540 fabrics, why is that? I followed the attached images
    Hi, thanks for posting. It is the same for 3ds Max and Vantage. I suppose the fabrics that do not show up in the Vantage browser are using unsupported features. Let me research this and I will get back to the thread.
    Vladimir Krastev | chaos.com
      Hi, we discussed the issue with our Cosmos teammates and found the solution. You should now be able to use all available fabrics in Vantage.
        Good morning, I have a question:
        1 - Vantage - 537 fabrics
        2 - SketchUp - 540 fabrics
        3 - And in your attached photo, you have 706 fabrics
        I've attached the 3 photos now for you to see
          There are 3 assets in the "Fabrics" category that have different requirements and are not currently enabled for Vantage. The screenshot with 706 results used the search function instead of the category.
          Nikola Goranov
          Chaos Developer
            Hi, the search engine finds the the key word "fabric" in other models as well. That is why we have this difference, if we go to categories then it is only the fabrics themselves.
