Can anybody suggest a method to create a realistic pool water texture with faked caustics/foam relfections etc etc. All the methods i know involve the use of displacement maps or blend materials neither of which are supported with Vantage. Any help would be much appreciated as I'm out of ideas.
Realistic Pool Water in Sketchup + Vantage with no Displacement or Blend Materials.
Hi NRH1981,
For the animated water I would suggest to heck the following thread:
https://forums.chaos.com/forum/chaos...31#post1162531
To fake the caustics one way would be to use an invisible rectangle light with Directionality near 1 positioned at the water surface and use an animated texture of caustics, I used the free sample from https://henrikbc.gumroad.com/?query=caustics_vol_1:
https://drive.google.com/uc?id=1Q3u-...Cgd7La6Rw_Va3m
In the end you would achieve a similar result:
https://drive.google.com/file/d/1c8z...ew?usp=sharing
Hope the suggestions will be helpful to you.
AlexanderLast edited by Alexander.Atanasov; 17-09-2024, 06:28 AM.Alexander Atanasov
V-Ray for Unreal & Chaos Vantage QA
Chaos
Thanks Alexander.
We have been using vray-vantage for predominantly standalone render production (its extremly quick in comparison to standard Vray-GPU) and we were able to make a 70%-80% convincing water texture with Caustics using your methodology above.
Thanks for the links; they were very helpful.
