Reusing cameras in Vantage 2
  • Reusing cameras in Vantage 2
    Can I reuse cameras setup in one Vantage project for another project with a different name? For example: opt A cams for opt B.
    I don't think you can do this directly, but you could try finding the "cameras" section in the .vantage file and transplanting it onto the second .vantage file (at the same relative position). This assumes the two use the same base scene or at least that using the same coordinates makes sense in the second scene. Make a backup of the file before editing, just in case.
    Nikola Goranov
    Chaos Developer
      Ooh...will try that. How do I open .vrscene? Notepad or just open?
        Some text editor. If you just try to open it with double click, it would run Vantage.
        Nikola Goranov
        Chaos Developer
