Composite Mix for bump material
  • Composite Mix for bump material
    Modified
    Textures
    • Support for mix_amount parameter for 3ds Max's Composite texture.
    Thank you for this!
    Is the composite texture also supported in the vray material bump slot?
    No, only bitmap textures are supported for bump.
    Greetings,
    Vladimir Nedev
      Thank you, for clarifying! Are there plans to have any other maps be supported in the bump slot?
        Yes, but we can't give you a time frame. And results won't match V-Ray for 3dsMax when we eventually support this.
        Greetings,
        Vladimir Nedev
