Is there a tutorial on how to use this? Does it only work with Vray sun and not HDRI maps? Does it work with light?
Vantage fog Scattering tool
HI, thanks for posting. Could you explain in a bit more details what do you want to achieve? VRayEnvironmentFog is supported trough Live Link from 3ds Max. You can also add fog to your scene in Vantage.
Originally posted by Luma3d View PostIf you look at the menu you posted, there is a scattering fog section. How to do properly use that? Does it work with my hdris or do I need to use vraysun for that option to work properly.
So it might be easier to just use the sun light.
Greetings,
Vladimir Nedev
