Quick one, when I import the rendered mp4 files into After Effects, After Effects will interoperate the footage as Rec 709, rather than sRGB.
When I manually change the interoperate footage settings from Rec 709 to sRGB the footage is identical, so I don't see why the mp4 files are being read as Rec 709.
The reason why this is an issue is that we're using the mp4 files for pre-vis, then replacing the footage in After Effects for the rendered exr files. However we're having to manually change the interoperate footage setting for ever file, which is time consuming, and prone to user error too.
Dean
Dean
