fire and flames with Cinema 4d.
  • fire and flames with Cinema 4d.
    HI,
    I was trying to reproduce flames for a biethanol fireplace but I saw that the alpha channel in the light material doesn't work. Is there an alternative way?
    Because I tried with diffuse material but the effect is too fake
    Thank you​
    Hi, thanks for posting. VRayLightMtl with opacity is not supported in Vantage. We have this issue logged in our internal system under LAV-582. I will add your thread to it and raise the priority.
    Vladimir Krastev | chaos.com
      Originally posted by visualtracing__ View Post
      HI,
      Thank you​
      Can you send us an example C4D scene so we can figure out exactly what's not working ?
      Greetings,
      Vladimir Nedev
        Greetings,
        Vladimir Nedev
        I wanted to reproduce this flame through a moving frame sequence in a light material, in order to have the lighting that varied like the movement of the flame itself.
        alternatively I can recreate everything except the standard material but I will not have any lighting contribution. I could put a hidden fixed light.
          Can you send us the C4D scene with the textures ? It could be just the flame and its material/textures.
          Greetings,
          Vladimir Nedev
            Certain,
            I attach the two versions.​
            https://e.pcloud.link/publink/show?c...TrFRhi8pKJpJU7
            Let me know
            thanks
