A few scripting question...
  • A few scripting question...
    When I tried to render animation with 3dsMax live link, it opens Vantage Render Setup dialog.
    I need a way to set those settings with script and start render.
    How can I do that?
    Also, during the live link, I need to be able to update resolution.
    How can I do that?
    Hi, thanks for posting.
    Do you mean this one? You can't use script for as far as I know but will check again.
    Once you have started rendering an animation you can not change the resolution until the rendering is complete.
    Vladimir Krastev | chaos.com
      Any update on this?
      I'm seeing tons of post for batch render.
      I ideally I need to be able to set all seq render settings _ render elements from Max and trigger render.
      I also need to be able to Camera related setting, especially aspect ratio, from Max, too.
