Display Correction
  • Display Correction
    How do I turn off Display Correction in Vantage?
    This is what I'm looking for: None
Name:	Screenshot 2024-04-10 221439.jpg
    Marcin Piotrowski
    youtube
    Hi Marcin,
    There is no such control in Vantage it is sRGB only at the moment. We already have logged requests for OCIO/ACEScg (LAV-588 )and we plan to add it in the future. We will discuss internally for your request and get back to you.
    Alexander
    Alexander Atanasov
    Chaos
      If you want to see raw linear colors, this is currently not possible in the viewport. You can only output "Raw RGBA" as a render element in offline rendering. Can you confirm this is what you're asking for and whether you need it in interactive mode?
      Nikola Goranov
      Chaos Developer
        I was just looking for an option to have the viewport in Vantage without Display Correction​ as I would like to manage that through a lut. If this is always ON and sRGB - no worries, I can just add the reverse transform to luts I'm using, not a big deal. Now everything works as expected (at least with LUT Color space option Linear)
        But on that note:
        what is quite unintuitive is LUT Color space options sRGB and V-Ray Log as these work differently to same options in VRay's VFB: after the conversion and applying lut Vantage seems to go back to linear instead of staying in log or srgb.
Name:	Screenshot 2024-04-11 110604.jpg
        Marcin Piotrowski
        youtube
