Can you give us more context? Are you using the latest version 2.5.2? What are you doing, is an animation playing? It looks like something is changing the scene and this resets sampling.
The sampling noise may improve if you enable "Direct light reservoir resampling" in the Render settings panel.
Vantage keeps flickering while there are no changes made in the scene and also while the live link animation is being rendered.
Here is the link to show this issue.
How can i solve this issue?
Strange, it looks like Vantage is getting some update over live link every ~3 seconds. I don't know why. Does this happen if you start V-Ray GPU IPR instead?
yes, I noticed that too. i was going to open a topic for this now, I saw the title. there was nothing like this before 2.5.2. this is a problem that comes with the latest version. as if DLSS is not working
DLSS is only used in interactive mode. The issue reported above is in offline render mode. Are you having the same issue? Did it occur only when you updated to 2.5.2 (without updating V-Ray, etc.) ? If so, does it go away if you install 2.5.1 or 2.5.0 again?
Dug a little deeper and noticed that if I turn off the tilt camera correction in 3ds max's vray camera the flicker stops... works normal. I also noticed that if I have a physical camera in my scene, Vantage does not update as I move around in my viewport.
