Flicker on reflection for very inox machinery
  • Flicker on reflection for very inox machinery
    I render video of machinery with many steel and glass, 300 sampler with hight quality
    I wish to be able to remove most of the flickery effect on low glossy reflection I would like to have some suggestion on witch parameter play with to push the quality without compromise to much the speed, I have notice that elevating the sampler the quality Increase but maybe you can guide me more deep I cant find a specific tutorial LINK of short video
    If you are using more than a couple of light sources, try enabling "direct light reservoir resampling" in the render options. Are you using the Optix denoiser with "reduce flickering"? This is the only temporally stable option for offline rendering.
    Nikola Goranov
    Chaos Developer
      I will try, I'm using a vray dome with HDR 8k and I have 3 vray light just to increase some effect
        In this case reservoir resampling probably won't help much. It's useful when there are many lights. You may just have to use more camera samples.
        Nikola Goranov
        Chaos Developer
