floating window
  • floating window
    What shortcut or how can I make a small window hiding the settings in Vantage?
    https://lookrender.com/
    Hi joaquin_pradoscordon,
    The UI can be toggled with the Ctrl +` shortcut by default. You can reassign the shortcut from Edit->Mouse and key shortcuts menu:
    Alexander​
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      thank you so much
        Alexander​
        Hopefully it can be like some video players, such as Potplayer. In Toggle mode, press Alt+1 for the original resolution window, Alt+2 for double the size, and Alt+3 for triple the size.
        Software: 3DsMax 2021.3 / 2024.2 | VRay 6 GPU + Chaos Vantage
        Hardware: i9-13900k | RTX 4090
        e-mail: imhill820@gmail.com
          It would be nice if you could double click and it would alternate.
            Click image for larger version  Name:	image.png Views:	79 Size:	29.4 KB ID:	1219652
            Alexander​
            Please provide an option to use this floating window without the UI in Max while using LiveLink.
            When I click a button outside the window, the toggle gets disabled.
              Hi Pablo,
              What do you mean the "When I click a button outside the window, the toggle gets disabled"?
              If you have enabled Always on top (the pin button on the right side of the menu bar or with the default shortcut Ctrl+Alt+T) and the Toggle interface option with the shortcut you should have the Vantage viewport with only the title bar visible on top of the Max UI. If this is not the case can you record a video and send it?
              Alexander
              Alexander Atanasov
              Chaos
