Light multiplier controllers
  • Light multiplier controllers
    Do the work with Vantage? I'm trying to create flickering light in an animation.
    Are you trying to do light flickering inside Vantage or export such an animation from Max? If you are exporting an animated vrscene or using Live Link animation - they should work. Creating a light flickering effect in Vantage itself currently will require the scene state system. You would have to create scene states where the lights are on and off and assign those states to cameras and use them in the camera track. However this will probably require to create a lot of cameras/states in order to get a proper flicker effect and not just a dimming effect. So I would suggest you try with the animation setup in Max and then export an animated vrscene.
    Alexander
    Alexander Atanasov
    Chaos
      It seems to be working. I added a noise controller to the vray light and exporting the frame range to Vantage.
