OCIO substitution for Vantage
  • OCIO substitution for Vantage
    Set of luts for Vantage - a fix for missing ocio support.
    ACEScg and sRGB scenes
    OCIO config for VRay included
    48 luts for Vantage + ocio config
    luts in Vantage require Highlight burn adjustment = 0.0
    8 view transforms and 3 displays (sRGB, gamma 2.2/BT.709 and rec1886/BT.709):
    - aces-rgc: ACES 1.0 SDR-video RGC view transform for environments without OCIOLook support: https://docs.acescentral.com/specifications/rgc/
    - filmlook01: traditional film emulation
    - filmlook02: black and white film emulation
    - cinemalook01: classic teal and orange look
    - cameralook01: famous K1S1 lut from ARRI https://www.arri.com/en/learn-help/l...t-generator​
    - AgX-Punchy: view transform by Troy Sobotka: https://github.com/sobotka/AgX
    - Unity-neutral: Unity neutral tone-map from Maya's ocio config
    EDIT:
    - ACES 2.0 rev060 view transform
    OCIO config from this post: https://forums.chaos.com/forum/chaos...er#post1221708
    OCIO LUTS for Chaos Vantage available here (not a freebie this time):
    https://piotrus3333.gumroad.com/l/hokkh
    how to:
    Click image for larger version  Name:	Screenshot 2024-12-19 122527.jpg Views:	128 Size:	44.1 KB ID:	1223443
    samples (acescg scene, Vantage vs VRay):
    filmic AMPAS:
    Click image for larger version  Name:	00_vantage_ampas.jpg Views:	127 Size:	119.0 KB ID:	1223444 Click image for larger version  Name:	00_vray_ampas.jpg Views:	131 Size:	143.2 KB ID:	1223445
    Vantage lut aces-rgc vs default 3dsMax aces:
    Click image for larger version  Name:	01_vantage_aces-rgc_srgb.jpg Views:	131 Size:	117.9 KB ID:	1223446 Click image for larger version  Name:	00_vray_default-3dsMax-aces.jpg Views:	129 Size:	137.8 KB ID:	1223447
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
    Vantage luts filmlook01 and cameralook01:​
ID:	1223449 Click image for larger version
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      Vantage vs VRay comparison with all the view transforms:
      https://we.tl/t-oGLkgoujhS
      edit: do not worry about the red “laser” light in acescg scenes - this is a stress test - it’s pretty much infrared territory. if you tone it down a bit into PBR range it will look nice - unless you are using any filmic or default aces from autodesk.
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        mP_OCIO LUTS for Vantage v2:
        + ACES 2.0 rev060 view transform
        Vantage vs VRay - ACES 2.0 rev060 gamma 2.2 display (sRGB primaries scene):
ID:	1224700 Click image for larger version
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
