Water Surface - How to scale it correctly
  • Water Surface - How to scale it correctly
    Hi
    I m using the new Water Surface object and it works quite well, but I do have some problem getting it to work if I scale it up. I need it to simulate ocean so I add the Water Surface object (looks good), then I scale it up from 1 to 10 and adjust the Scale factor in options down to 0.001. The water Surface is still not big enough but I m not able to use the scale factor lower than 0.001. Any one have any tips for making bigger water surfaces? The other options just make big strange "waves"
    Hello, Harald!
    We had one more similar complain recently and will address this in the near future.
    Thank you for reporting these issues!
      Thank you!
        Hello once again, Harald!
        In the new update all should be fixed with the scaling!
        Cheers,
        Kostadin
          Hi. Thanks ! I havent tested it out yet, but will do soon
