Hi, how do i get my vantage to look like this, where there is no tool bars or buttons
simplified renderview
You can do this with Ctrl+` (if instead you only press ` it will capture your mouse for "first person" navigation). You may want to toggle "always on top" first before hiding the interface - it's the pin icon in the top right corner. This will keep the window over 3ds Max.
You can find the shortcuts in Edit->Mouse and Key Shortcuts.Nikola Goranov
Chaos Developer
- Likes 1
Originally posted by npg View PostYou can do this with Ctrl+` (if instead you only press ` it will capture your mouse for "first person" navigation). You may want to toggle "always on top" first before hiding the interface - it's the pin icon in the top right corner. This will keep the window over 3ds Max.
You can find the shortcuts in Edit->Mouse and Key Shortcuts.i wasn't able to get it to work, but as able to make a short cut with the Mouse and Key Shortcuts.. got it working. thank you
