Road Markings
  • Road Markings
    I'm new to Vantage, and still learning the basics. Right now i'm trying to replicate the road markings made in VRay, into Vantage, but i had no success.
    If i use only decals, there will be hundreds in one single scene, also i don't think flooding a scene with decals would help in the GPU load.
    Is it possible? Can anyone help me with this?
    Thanks in advance.
    Hi julio_verani,
    Can you share how does your V-Ray setup for the road markings look like?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      If i use only decals, there will be hundreds in one single scene, also i don't think flooding a scene with decals would help in the GPU load.​
      I don't think it will be too much of a problem (as long as the decals are not all on top of each other).
      Greetings,
      Vladimir Nedev
        Any word if distance mapping will be implemented in Vantage so that it can be used as a map channel with vrayblend?
          Hi Luma3d,
          Distance map is not currently planned but you can achieve a very similar result with the Dirt texture. Here is an example how to do that (https://drive.google.com/file/d/1NUS...p=drive_link):
          1. Make the radius large enough for the markings geometry
          2. Increase the distribution very high to reduce the falloff gradient
          3. Include only the markings geometry in the Affected by... list
          4. Reduce the markings geometry to a very low number 0.001 for example
          Tell me of this setup works for you?
          Alexander
          Alexander Atanasov
          Chaos
            Hello Alexander, can you please upload your 3DS max scene with this material and setup? I cant replicate it... Thanks!
            Or maybe fbx? I have older max version... (2022) thanks a lot!
            Edit: I tried to connect nodes little bit different and now its working (i dont know if its in correct way, but its working somehow Click image for larger version
Name:	Snímek obrazovky 2025-03-04 170635.png
              Ooh... awesome. Got to test.
