Isolate temporarily
  • Isolate temporarily
    I'm trying to use Vantage 2.7 with Livelink with a 3dsmax 2025 Vray 7.00.04 file, the file is pretty large, 15gb of Vram. Now, would it be possible in future releases just to work on a quickly isolated object in 3dsmax, say just adjust a few vertices without unloading the file?
    Also whilst in walk mode in Vantage it would be handy to have the option for 3dsmax to follow Vantage in it's viewport.
    Lastly does anyone know if Vantage supports multiple UVW channels, I have some brick with a diffuse map & a dirt map, dirt map is on channel 2 and fails to come through correctly, simple UVW Box applied.
    Many thanks for any help.
    Jason
    AMD Threadripper 3990x 64C Processor, 128 GB DDR4-3200 Ram, 48 GB PNY Quadro RTX A6000, ​Windows Pro 10.0.19045.4894, 3dsmax 2025.3, Vray 62006, Vantage 2.5.2​
    Lastly does anyone know if Vantage supports multiple UVW channels, I have some brick with a diffuse map & a dirt map, dirt map is on channel 2 and fails to come through correctly, simple UVW Box applied.​
    Multiple uv channels are supported.
    Does the same setup work in V-Ray ?
    If yes, please send the scene (just the object+material) to support so we can investigate.
    You can also attach it here if that's ok with you.
    Greetings,
    Vladimir Nedev
