I am trying to make work an effect that should give this result:
I am using tyflow and the operator responsible to change from black to white the gradient ramp in the visibility channel of the blend material is the one called MAPPING
Everithing work ok in vray but VANTAGE doesn't get the mapping info
It make like a mix for all the duration of the animation
Maybe you have some work around
https://drive.google.com/file/d/1siE...ew?usp=sharing
Thanks, I hope I made my issue understandable
