Lens glare... sade face
  • Lens glare... sade face
    I'm a little bummed. I was super excited that lens glare was added to the latest release, but disappointed that it needs a vray light to work. I was hoping that either a vraylight material would trigger the glare. Or even the vrymtl self-illum material. Now I need to add a more vray lights than I would like to get the glare effect. Any hope for the material based lighting to work with the feature in future releases?
    Hi Luma3d,
    The Lens effects do work with both light material and self illumination. If you are not seeing the effect the material' lighting intensity is probably below the threshold for the Lens effect to detect it. Can you either increase the intensity of the material or reduce the threshold in the Lens effect ?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Oh, ok. I'll check again.
