Perforated metal material not showing
  • Perforated metal material not showing
    I am working on a project through Revit. I assigned a perforated metal from Vray default library, however the material turns solid when we brought it into Lavina. Can anyone help me on this issue?Click image for larger version
Name:	perforated metal issue.JPG
    Hi danwei_wang,
    You have to enable "Opacity maps (clip)" option in the Render tab advanced section:
    https://ftp.chaosgroup.com/support/s...8_08-51-47.gif
    This option is OFF by default for performance reasons. If that doesn't solve your problem please send us the scene so we can investigate.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Thank you Alexander, problem solved!
