Not enough VRAM to render 4K
  • Not enough VRAM to render 4K
    I was loading in the files for the Building Utopia competition (https://buildingutopia.cgarchitect.com) and just tried to do a simple 4K render. Even though I have a RTX 3080 with 10 gigs of VRAM, I was unable to render in 4K (could only render at 1080p or 1440p). However, in the competition guidelines, it says that only an RTX 2080 Super (with 8 gigs of VRAM) is recommended. Any ideas on how to get the scene to render in 4K?
    Do you want to render with the denoiser enabled or disabled ?
    There is an inefficiency in our code right now, even if you have the denoiser disabled, we will still allocate the memory necessary for all its buffers, which is quite a lot in 4K resolution.
    We have to improve this, but I don't know what you could do before that.
    Greetings,
    Vladimir Nedev
      You could try disabling this option in Edit->Preferences. It is meant to prevent crashes, but when you're just only slightly above the limits it would probably still work fine without the safety checks.
      Nikola Goranov
      Chaos Developer
        Thanks for the quick response Vladimir and Nikola! I've tried disabling safe GPU allocations, but the application has crashed every time I do that. I'll probably just wait for some optimization updates in the future since there is no tight deadline!
          Never mind! I just tried disabling safe GPU allocations (via the settings/preferences menu versus the popup that appears) and it seems to work! I think it was barely above the VRAM limit so it worked fine. I'll reply to this thread if any more issues appear.
